Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Can I glue my iPhone 6 screen back into its frame?
basically my phone started to pop out and first it was okay cause I couldn't really see it and it wasn't that bad but I dropped it now and I can literally pull the screen out of its frame, it isn't smashed or anything perfectly working fine I just earned to know can I glue the screen back into its frame as its just popping out the frame and if so what glue do I use so it doesn't pop out? (The screen is just popping out the glass frame)
Score 3
Add a comment
Chosen Solution
Which button is it making loose? The home or power button? Can you glue it down? Well, you can. I've done it before, as a temporary solution. This is pretty much a temporary solution. Eventually you'll start to lose functionality in multiple areas. I would suggest replacing the display assembly
Here's parts
iPhone 6 LCD and Digitizer
Here's labor
iPhone 6 Screen Replacement
Now, with that being said. You could use as Devin Nash said, gel super glue. I've used double sided 3m tape. You kinda just want to use it sparingly in the areas that yourscreen is coming up. Make sure to hold pressure onto the area, after applying the adhesive, so that it will stay down
This is one of the most common adhesives I use
[linked product missing or disabled: IF145-283-2]
iPhone 6 LCD and Digitizer Image
Product
$69.99
Score 1
7 Comments:
basically everything is working fine I've had my screen replaced before and the glue on the screen frame was loose but I ignored it and now I dropped it got worse? now my middle Touch ID button is loose as the screen is coming off if you understand what I mean? but what am asking is can I just glue the screen back into its frame down (I can see the bits where it's been glue as you can see the glue) , I've been thinking about going to a shop and just getting a new screen but is there a point because my screen isn't smashed?? and it works amazing. My screen is exactly like this YouTube video just its out way more http://youtu.be/fDkC0LRMFnQ. Get back to me please
by
btw I have an iPhone 6
by
Sorry, I linked parts and guides for an i5. You can glue it, however, after some point it'll just start to lose functionality, like I said above
by
what do you mean lose functionality ?
by
Things will stop working
by
Show 2 more comments
Add a comment
Most Helpful Answer
Yes, I like to use the GEL super glue and VERY sparingly. Just a touch in the corners and you should be good. DO NOT try gluing it on the side even if it's popping out there too because it will leak into the backlight.
Score 4
1 Comment:
I'm confused so where do I put the glue if I don't put it on the sides as the sides and top are popping out the frame the most it's makin my button loose
by
Add a comment
i just got glued my phone screen down. is that bad??
Add a comment
Just use a little bit of superglue and put it in the edges of the frame
Then it will be okey
Add a comment
Why not just put one tiny drop of B7000 glue on the side?
1 Comment:
I have the same question :) my screen is popping out on the side and not on the corner..or in the lower part..
Any way to fix it?
by
Add a comment
Add your answer
chevy will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 81
All Time: 26,375
