The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
help with wifi hardware
hey
i would like to know the wifi hardware on the hoc one m7
as its very week to detect the wifi
to connect i need to be just few cm near the router or it will not work thanks
Score -1
4 Comments:
Hi,
Have you tried connecting to a different router? Does it 'pick' up other networks (I know that you cannot connect to them). Are you trying to connect to 2.4GHz or 5GHz WiFi?
by
hey
it works only when am in few cm from the router
my phone had been prepared so i think some thing not okey on the hardware
maybe not correctly attached
its on auto mode so its both are selection 2.4 and 5 ghz
by
Hi,
Can you detect other routers or not?
by
yes but only if am near (less than 1 meter )
by
Add a comment
1 Answer
hey it works only when am in few cm from the router my phone had been prepared so i think some thing not okey on the hardware maybe not correctly attached its on auto mode so its both are selection 2.4 and 5 ghz
1 Comment:
Hi,
Looks like you are right. Maybe you should take it back to the repairer and get them to check their work.
by
Add a comment
Add your answer
attiouim will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 109
