Sound cuts out on 3 channels only after 1 second
The sound cuts out on only 3 of my channels after 1 second. There are no external devices connected to the TV. I completed the sound test (Suport > Self Diagnosis > Sound Test) on the 3 channels with the problem as well as a channel that doesn't have the problem and that didn't show any problems. Any thoughts? Thank you
Update (02/07/2016)
The TV is A Samsung 32 in flat screen, model UN32H5500AFXZA. The channels are not on the same network, however they are 3 of the 5 local channels (I don't need cable to access them, although I'm receiving them through my cable connection; I'm not having any issues with the other 2 local channels). You asked if I rescanned the channels. I didn't rescan, however I deleted all channels then added them. I wonder if deleting all of them then rescanning would make a difference. I'll try that. Thanks.
2 Comments
@mhellman what model is your TV? Just to make sure that I understand you correctly. You are losing sound on 3 channels only, not the rest of the channels?
by oldturkey03
Hi,
Do the 3 channels belong to the same network? Have you tried rescanning your TV channels?
by jayeff
