Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Questions View all
Question Closed
Upgrade/add (if I can) an SSD instead of my HDD
I want to Upgrade/add (if I can) an SSD instead of my HDD. My Imac only has a 1TB HDD and I want to switch to SDD or add one to make them as a fusion drive is it possible and can you guide me please ?
Add a comment
1 Answer
Chosen Solution
Review the guides below very carefully, it is very easy to damage the display assembly it you don't use the correct tools and use care!
Here is the IFIXIT guide to replace your HD (in your case swapping it out for a SSD): iMac Intel 27" EMC 2639 Hard Drive Replacement In addition you'll need the following:
Here is the IFIXIT guide: iMac Intel 27" EMC 2639 SSD Replacement As you can see adding the blade SSD is a lot of work. You also will need to find a compatible SSD unit, so far Apple is the only suppler either as a spare or from a system as a parts teardown. There are a few 3rd parties hinting on offering their own solutions in the spring. So for now it maybe wise to hold tight.
As far as setting up a Fusion Drive set you'll need to have both your current HD and add in the blade SSD. The idea of a fusion drive is having two physical drives act as one in this case both an HD & SSD. That way the OS can manage the storage space putting more needed files on the faster SSD like the OS and some of your apps.
Another approach is to use a SSHD which is a single drive that has a SSD acting as a deep cache for file access. Here too the SSD holds the more often needed files and the traditional HD space holds the majority of the files. Here's one example: Seagate 3.5" Desktop SSHD. You will still need the external thermal sensor: OWC In-line Digital Thermal Sensor for Hard Drive Upgrade for 27" iMacs 2012 and Later. Frankly, if you need to do this now this is the best option in my opinion.
iMac Intel 27" EMC 2639 Hard Drive Replacement Image
Guide
Difficulty:
Moderate
30 minutes - 2 hours
iMac Intel 27" EMC 2639 Blade SSD Image
Guide
iMac Intel 27" EMC 2639 Blade SSD Replacement
Difficulty:
Difficult
1 - 3 hours
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 148
