Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Question Closed
After iPhone 5c Broken Screen Replacement. Camera test issue.
Hi
After screen replacement I can't seem to press or test camera button on lock screen. Please help.
Screen seems to work, I can press pass keys or dial keys on lock screen.
Thank you for your time.
Add a comment
1 Answer
Chosen Solution
You will have to open phone again - you have problem with connector - use magnifying glass and after disconnect inspect all pins on both sides of connector (camera and Motherboard. if everything is ok, clean contacts with Alcohol ( not Whiskey please). Reconnect and check if connection is firm ( you will feel Click sensation).
If this is not the case check your date and time settings - sometimes this causes all kind of troubles - mostly with WiFi but had cases when was playing with camera too.
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 38
