Samsung 2333hd back removal.
How do I remove the back cover from Samsung 2333HD?
@angela2 this from the service manual should help you out:
Place monitor face down on cushioned table. Remove Stand, then remove 4 marked screws from the rear cover.
Caution : If you do not tilt the stand and use too much force to remove it, the connection pin may break.
Remove the cover and the LCD panel using the provided jig on both grooves at the bottom.
Caution : Remove the cover and the LCD panel using the provided jig on both grooves at the bottom. If you disassemble the product with only one side opened, it may be damaged.
Insert a flat screwdriver into the groove and then lift up and remove the cover.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,204
