1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Questions View all
Question Closed
Need to know what to do to update to at least Mavericks.
What do I need to do to get my Mac mini to update to the el capitan? Should I change the hard drive? It works perfectly. Just need it to update!! What components do I need to change to make this happen?
Add a comment
Chosen Solution
Sadly its just not possible, the hardware is limited here. The highest OS this series can support is Snow Leopard (10.6.8) in 32bit mode. This also limits you to older 32bit apps. Which you'll only find in the used software shelves.
I guess its time for a new Mac mini!
Score 2
Add a comment
There are some hacks around to get it up to 10.7.5.
Install Lion in the standard way, boot into your old OS, delete the 'PlatformSupport.plist' from your freshly installed Lion partition (it's in 'System/Library/CoreServices') - then Lion will boot just fine :-)
1 Comment:
Thats al well and good for Lion as it still has a dual code set (32 & 64bit), El Capitan does not offer any 32 code.
I would stick to Apples recommendations here, Snow Leopard being the highest I would go with. The CPU will struggle with anything newer.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 160
