Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Powers up, then shuts down
Hi there guys
I have here an iPhone 5S that does something rather strange. I have recently refurbed the whole phone with new components, inc battery and screen.
The phone powers up, shows the Apple symbol for about 2 seconds then the screen goes blank, however you are able to see the lit up backlight. It stays on for about 15 seconds then shuts down, any ideas of what it could be?
Regards
Fonebitz
Score 1
Add a comment
Chosen Solution
Issue was it just need to be restored through DFU Mode
Add a comment
Try resetting your screen cables connectors and do not have the shield cover for the screen connectors and see if it reboots.
1 Comment:
Done all the obvious, but still nothing
by
Add a comment
Are you 100% sure all the screws are in the proper holes on the lcd/digitizer bracket? If one of the slightly longer screws is put in the lower right hand screw hole, you could possibly damage your board or put pressure on the board until it behaves the way you are explaining. I have seen this happen personally. I would remove the screws and that bracket. Then Id test it out.
2 Comments:
I powered on the phone without the Connector bracket to test it and still the same, I also did it with the bracket and correct screws (checked 3 times) and no change
by
Do you still have the old battery? I have seen bad batteries (even new) cause iPhones to act crazy. Its worth a shot.
by
Add a comment
Add your answer
fonebitzltd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 106
