2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Is my mid-2012 MBP overheating?
My mid-2012 retina 15" MBP has been getting increasingly hot for the past year or so. I think the trackpad has been causing some minor damage to the nerves in my fingertips (either from heat or worn-out finish, if that's possible).
These days, the CPU temperature typically gets somewhere around 160℉ and the palm rest temp gets somewhere around 85℉. You can view a full temperature breakdown here.
Are these normal operating temperatures? If not, what kind of tests can I run to determine what the problem is or what parts I might need to replace (fans, heat sink, etc)?]
Score 2
Add a comment
1 Answer
Chosen Solution
The temps are about normal, some are on the high side but not by much.
I would guess your system is likely dusty inside. A can of can'ed air a small soft paint brush to scrub the fan blades and heat sink fins is all you'll need here after popping the bottom cover following this IFIXIT guide: {MacBook Pro 15" Retina Display Mid 2012 Lower Case Replacement|MacBook Pro 15" Retina Display Mid 2012 Lower Case Replacement]. Just be careful here as you don't want to damage your system follow good ESD protection practices as in the winter with the dry air it's a system killer.
As far as the trackpad: Have you tried clean it with some isopropyl alcohol? Slightly dampen a paper towel and tried just wiping it down, The trackpad surface is glass so I doubt you damaged it just from regular use. They do get dirty from the skin oils and other junk that gets onto them. Replacing the trackpad is not something I would recommend you try in this series as its a very big job. Best to bring your system into an Apple Store and let them do it if its that far gone.
Score 4
2 Comments:
Why isopropyl alcohol?
Sorry for getting back to this so late.
by
A high grade isopropyl alcohol will evaporate quickly, water won't which could cause more problems, and any cleaner will leave a residue which could damage the trackpad.
by
Add a comment
Add your answer
travismlive will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 15,247
