Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Questions View all
Why won't my screen turn back on?
I have an iPhone 4 and it froze yesterday evening. I went to plug it in so I could turn it back on because my lock button doesn't work anymore. I heard the sound it makes when you plug it in but the screen just won't turn on. Any suggestions?
Add a comment
1 Answer
Chosen Solution
An iPhone without lock button function is difficult to trouble shoot and repair.
First step would usually be a simple Reset, which you cannot perform due to lock button failure.
Since you believe the iPhone is working except for the screen being OFF, connect iPhone to iTunes on computer to see if it is recognized and seems to be OK otherwise. If not, try to Restore it with iTunes.
If OK with iTunes, you could wait till battery completely runs down and then power it up with charger. I would open up the iPhone and very carefully disconnect and then reconnect the battery. If this is not done properly you will dislodge the receptacle from the logic board and further destroy the iPhone. When you connect the iPhone back to power see if it starts up OK. If not, consider Restoring iPhone with iTunes on computer.
You may need a new screen and while replacing that consider repairing the lock button flex. I have seen perfect used iPhone 4 going for low prices, around the cost of repair shop prices to fix an iPhone in the condition of yours.
Score 1
Add a comment
Add your answer
Destiny Nicole will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 121
