Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
iPad won't turn on and iTunes doesn't recognize it.
After a LCD and Digitizer repair, the iPad doesn't seem to turn on at all.
Score 1
Add a comment
Chosen Solution
It was a bad LCD... :/
Add a comment
Most Helpful Answer
Doesn't turn on, doesn't seem to? What happens when you plug it into a wall charger?
Score 2
5 Comments:
Nothing happens when I plug it into a wall charger.
by
Check your battery connections. Even if your display isn't displaying. It would still buzz or actually turn on without you seeing it. Even if you can't see it
by
So disconnect the battery ribbon and reattach it? I've tried that. Is it a blown fuse or bad LCD?
by
Sounds like a damaged logic board. I don't think the LCD is the problem
by
Hmm. Weird. Well, glad you found the problem
by
Add a comment
Add your answer
Brendan Nellis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 251
