The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
f2 error code dispayed
Washer does not drain or spin. Dont know if has to drain before it will spin. Motor is louder then normal for pump to drain water. how do you get the front bottomn panal off to get to pump or do you have to dismantle the whole dangknab contraption to replace a simple part?
Add a comment
1 Answer
Chosen Solution
@stinkydad2000 F/02 error code potential causes
Check the drain hose and make sure it is not plugged or kinked
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects
If the above does not correct the problem replace the pump
I would start by taking the lower front panel off. There are two bolts, one on each side of the panel, remove those. Once you have the panel removed, you will see a white plastic unit, that is your pump assembly. You should also see a round plug with a plastic tab across the front. That is your coin trap. Open the cap by twisting it counterclockwise and remove it. It may just be clogged.
You can download the service manual from from here. and there is further information on here
Score 3
Add a comment
Add your answer
Erik Savage will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 4,258
