13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Why does my MacBook always think its charging
My macbook says it is always charging. When I unplug my device iStats shows that the rampage drops to 0 but it still shows a charging/charged symbol on the battery. Could this be a logic board, dc-in, or battery problem?
Edit:
Score 1
Add a comment
1 Answer
Chosen Solution
Lets see if we can collect some diagnostics. Download this app: coconutBattery. Post a screenshot on what it shows here in your question (edit it).
I would also recommend you reset the SMC to see if that fixes things. Follow this Apple T/N: Resetting the System Management Controller (SMC) on your Mac.
Also take the time to clean both the power adapter and the computers MagSafe connectors. Get a cotton swab dampened with some high grade isopropyl alcohol (85% or better).
Update (01/15/2016)
The charging circuit is having problems! Note the zero charge 0 mAh for current charge.
You may need to clean the MagSafe connector contacts on both the power adapter and the system. Use a cotton swab dampened with high quality isopropyl alcohol (85% or better). You may need to replace the DC- In Board. If your power adapter has a damaged cord its time to replace it as well.
The batteries condition is not good either. You're near the max charging cycles (967) designed for 1000 cycles. Its time for a new battery.
Score 2
2 Comments:
I reset the SMC almost daily (sometimes it can't boot without it) but no go. Will a dead battery think its always charging?
by
alright thank you and if cleaning doesn't help?
by
Add a comment
Add your answer
Sebastian McBride will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 4,677
