Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Touch ID not working
Ok so I replaced a screen on a iPhone 6 Plus everything went well. After it was done the Touch ID was not reading my finger... home button worked well and all but just wasn't reading my finger. I took it back apart to look over it and I did notice some rust on the speaker and a little bit of corrosion on the home button. I cleaned off the connector and got rid of all the rust and corrosion. Now I put it back together and still the same. I was working before the repair what could have went wrong...
Score -1
1 Comment:
What was damaged with the phone. Was it water damaged?
by
Add a comment
Sounds like water damage to me. You could try cleaning the areas affected by rust and corrosion with 99% Isopropyl alcohol.
I would also highly recommend never to try and update or restore this iPhone or you will end up with error 53!
Add a comment
This happened to me as well after a friend helped me with a screen replacement.
In my case - I think - it was the home button flex cable.
After replacing this flex cable - my Touch ID is now working again.
Do not take my word for it - but if you can, open it up again and inspect flex cable - and most important - the small connectors.
Add a comment
Add your answer
pspgoplaystation will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 189
