Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Stripped weight of the 13-inch non-Retina MacBook Pro, MD101LL/A?
I mean, the net weight of the device, stripped of its
- battery
- DVD drive
- the hard drive replaced by an SSD?
Score -1
Add a comment
Chosen Solution
I did some (actually heavy) Googling, and here's how I can answer my question now. Let's use metric units, as they can be more nuanced:
Weight of MacBook Pro 13-inch, 212 model: 2060g
Battery: 340g
Optical drive: 160g
Hard drive: 95g
SSD: 85g
Take out the hard drive, optical drive, and battery, insert the SSD and you get: 1550g. That is 30g lighter than the 1580g 13-inch Retina MacBook Pro, including battery. Sounds reasonable!
Score 1
Add a comment
Most Helpful Answer
The original specs indicate the weight of this is 4.5lbs. Subtract the weight of the individual components specified plus the weight of the SSD and you get about 1.37lbs total.
Original: 4.5
Battery : 2
Optical Drive: 1
Hard Drive: .57
SSD: .44
1.37 lbs
Score 2
4 Comments:
Interesting, Matt, however I'm still hesitant to press the 'Accept Answer' button. From where your number came from?
1.37 lbs is less than the iPad Pro for a unibody chassis, screen, keyboard, trackpad, SSD for the model MD101LL/A (2012), which I find highly unprobable (i'm just guessing here).
For a comparison, now I'm writing from a ThinkPad T400 (http://www.thinkwiki.org/wiki/Category:T...) with the same setup (with SSD, battery and DVD removed), though it has different proportions, its still a monster, almost 3 times as heavy as your final number.
by
Can I ask a dumb question here. Why are we debating this? Are you trying the rationalize what makes one system better than the next?
by
It's a fair question @docbrown
I got the numbers using iFixit's internal weight data on the items. I had to use a best guess given a random optical drive, hard drive and SSD option without knowing the size of each. The battery is accurate though.
by
Matt, some questions aren't worth your time answering. Time is finite, use yours wisely.
by
Add a comment
Add your answer
Doc Brown will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,351
