Why I can't reset my password?
I was forgot my smartwatch password and now i can't use it it's GT08 smartwatch
If you haven't changed it yet, the factory set password is "1122". If you did have a password and forgot it, you may want to factory reset your watch.
Hope this helps.
Its not working
Who well Doctor it and there ie password
How well factor it and there is password
How do you perform a factory reset on this particular one, I have one with the same issue and would like to just factory reset back to like it was when I first got it but can't remember what I did with my instructions manual. Any help would be nice, I've searched the internet and still can't find anything.
I need help with the same thing
Simply remove the battery
Wait for some minutes
Insert the battery again
Switch on and type in factory set password - 1122
Problem solved!
Can u help? I had already set connectivity and network but still can't download apps. Pop up Browser.... would you like to download and install... I clicked Install but did'nt work
connect it to computer and try from google apps store more likely it works you can download and install or uninstall from google android apps. hopefullu it works, Nest of luck.
it still say wrong password
it is off when i have on it the smart watch that it asked password. input phone password
it doesn't"t work
i have smartwatch zd09 i forgot my pass word which i type 1122 factory reset pass word i used but cant can you help me to solve this prob
Please help me...I sell smartwatches I sell a search Z36 brand new I have never tested or connected it to my phone before. But why showing customers a wicked customer must have put in a password,I cant remember who it is,I cant unlock my the password and I have never commected it to my phone. How do I reset it so I can sell it please
Switch on and type in factory set password - 1122*
Restart pass word 1122
Restart pass word 1122 Thanks
The prescribe password ie.1122 which i enter is denoted as incorrect password. Please help
I have the same ... :( and after Putin ing 3 times a pin code, it switch off by itself. What to do
the code is 1122 (factory)
no i change my password and when i turn it off i dont remember the password
I have bought a dz09 smart watch and it as enetered password recently and he don't told me the password kindly told me any way way to Hard Reset my watch.
Kindly tell me as soon as possible.
dz09 go to the dialer ( as if you was going to make a phone call and enter this to restore the phone and reset the password ....Restore factory settings: *#987*99#
I have foxwear camera watch. It is working in LAN mode(local mode) but when I try WAN mode then APP(sysm monitor) needs password. That password I can not find ??? The leaflet which I have received with camera watch has some passwords but none of them are ok for remote access.
i have been having much issue then i went on you tube n figure it out first you get the password screen with 3 trials i type in 1122 then i hit ok its going to say wrong password at this point it takes you back to the password screen where u have 2 trials left i type 1234 then hit ok and its going to again said wrong password i type 1234 again n it said done meaning it work SHOCKING but it work i have been messing with this phone now for a week hope it work for u guys i have the DZ09 Smartwatch with the copperface thnaks
How didi you do it? I have the same watch. I kinda forgoten my password too. Pls help me. Thanks
Wrong password
1122 is default password, unless you changed it then forgot it; I don't think there's any way of recovering it unless you use PC Software (If there are any for this, which I don't know yet) but I just got the smart Watch and 1122 worked as default password for Watch Lock Security.
Hey guys, I had this issue where I couldn’t reset the Spacetalk series 1 due to not knowing what my password was - I eventually found that it is the last 4 digits of the IMEI number, this can be found if you go into the information tab on the watch - hope this helps :).
My watch is watch 7 model W26+.please help me itbis locked
I recently bought a smartwatch watch dz-09 but when i wanted to restore factory settings,the default password did not work(1122).What can I do pls help
I need help with trying getting back in my smart watch i recent forgot my password Nd I can't get back in my smart watch
What do i do when i forgot my username and password?
thanx
I tried 3 times, first 1122, 2nd 1234, 3rd 1234 but Pass word
recently just purchased this smart watch for my husband as well. as soon as we turned it on it asked for the phone pass code. so reading the owners manuel i saw the code 1122 , we entered the code and still nothing. I’ve tired codes 0000 , 1212 as well as 1234 and still nothing. there is no way to bypass this screen. the smart watch gives you 3 tries to enter the pass code once you enter the pass code the third time the smart watch shuts off.
I'm having the same problem
input phone password for W008
I do not have a keyboard when I type in a password, only a number board. So I cannot type in the W
I have a GT08 I can’t the i can’t bypass my password
I cant get in to the watch i tryed 1234 and1122 but they didnt work i got the watch from a pawn shop bit no luck on findimg the password
I have T500 pro when i reset it and go for putting password again it asks wrong password.I tried different passwords to set but it asks wrong password please help me.
I have Z3 hottech smart watch i had put passcode ,but I forgot how do I reset it again ,I tried 1122 but still showing wrong passcode can you please help to reset it
I have type in the code but still is not working 1122 and 1212 plus 1234and also 0000
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 62
All Time: 117,760
25 Comments
How I will return it back please answer me
by Karooom Sandoka
Thanks for helpful information :)
by basvantk
how to reset noise smart watch
by abhishek.singh4012
My smart watch is model RYX-NX9 HOW Can I get its puk
please help
by vaibhavi Brahamwanshi
Hello I got a Chinese smartwatch the V8 and I forgot My password.
Is there any wat to reset it to the factory code?
Thx
by A Stolk
Show 20 more comments
