This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
355 Questions View all
Four pieces came off the camera when it fell off the shelf...
4 pieces came off - the round plastic piece around the lens, some bracket under that and I think the 2 shutters that go over the lens.....how do we put these back on? it looks like it should be simple?
Score 11
15 Comments
My close up lense won't fit into my camera and the first time I tried it, it worked fine, but I took it out and now doesn't fit.
by
what happen if one of the holes are broken
by
I don't remember dropping mine at all but when I went to use it the black part around the view finder was completely gone!!! I just got it, and I can't find where I can order the missing peice!!!! Can anyone help me???
by
Hi Ash, as I mentioned on the previous post, I 3D modeled that part. Despite that I haven't test it yet (a friend just printed it and it is on its way) I could send you the file if that would help you. Let me know!
by
My 2 year old broke this off and i think i throw out one of the yin/yang pieces not knowing what it was from!. Not sure.... and i cant find it either.... can you send the file to me as well?
by
Show 10 more comments
Add a comment
Most Helpful Answer
I just had the same thing happen, and I think I fixed it! The two little black pieces cover the lens when not in use. There are little holes at 12:00 and 6:00 (as if you are looking at a clock). The little black pieces have notches that fit in the holes, and the two pieces fit together like puzzle pieces (almost like a yin/yang symbol). The larger black piece that is more square sort of snaps in over top of those. There are guide holes. Then the lens part snaps back on. You might have to fiddle with it to get those two small pieces to fit, but it should work. Good luck!
Score 27
24 Comments:
Thank you, I dropped my daughter's camera and your post help a lot.
by
Sorry, I cannot get the square part to fit, can you hel me??
by
Is there anywhere I can buy new lens covers? Mine broke
by
thank you sooooo much!!! this helped A LOT!!!!!!!!
by
Thank you! i just hit my friends camera out of their hand when i went in for a hug--this saved me $100 and my testies
by
Show 19 more comments
Add a comment
Find the attached videos to fix this
Update (08/14/2021)
. Use this video
Update (08/14/2021)
. Use this video
Update (08/14/2021)
. Use this video
Score 1
1 Comment:
Worked great. Thanks I’ll be my granddaughter’s hero.
by
Add a comment
This also happened to me and I put it back together but now it won't work, was yours fully functional after?
2 Comments:
Yes, it works normally now. Though the lens part periodically pops off, so I have to press it back on. But it functions the same.
by
have you made sure that the batteries are put in correctly? It feels stupid to say but that was my problem after putting it back together
by
Add a comment
The back black piece around the lenses was loose and I ended up losing it after some time. In order to solve that, I am 3D modeling that piece and will print out soon. Even though it is still not possible for me to print out the notches (they are two tiny, and I couldn't find any disasembled piece to copy) I hope it will work out and prevent from dust get inside of the camera. If someone is willing to help me (with pictures/ dimensions of the isolated piece) I'd be more than happy to share my 3d files :)
1 Comment:
Hello Larielarie. Have you 3D printed this? If so I'd be interested in getting the file from you! I need to print one for my camera! Thank you!
by
Add a comment
Where can I find a replacement piece for the video above! The lens barrel end?
Add a comment
Add your answer
Joanmary Lavitz will be eternally grateful.
Past 24 Hours: 23
Past 7 Days: 103
Past 30 Days: 420
All Time: 73,361
