2.3L 4cyl or 3.0L V6, 6th Generation
426 Questions View all
Why wont my car start,
my car started to sputterand then it turned off, now it wont start,
Score -1
1 Comment:
Hi,
Have you checked that there is enough gasoline in the tank? Did you notice a low fuel warning light before the car sputtered and turned off? Does it try to start? What happens when you try to start it?
by
Add a comment
1 Answer
Your problem will be in the ignition or fuel system. The first step should be to hook it up to an OBDII scan tool and check for codes because there are many, many possible causes. This would help isolate failed electrical components such as crankshaft position sensor or knock sensor issues.
Barring that, if the codes are non-specific (you'll get codes for ignition issues and knock problems whenever you have a stutter, but historic codes would indicate a failing component) the first thing I'd look at for a Honda is the distributor cap/rotor, plugs, and wires.
Add a comment
Add your answer
beth gomez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 79
