The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
331 Questions View all
Washing machine going to sensing phase and then not working properly.
Our washing machine is going to point of sensing a start of water fill, 2 clicks then stopping, Cycle is then terminated and lid is unlocked. I have checked the water fill solenoids and the water inlet filters. Both good. Also have checked the diaphram pump line from the switch to the diaphram float switch. It is clear, empty, and no leaks.
Any suggestions? thinking possibly water pump?
Add a comment
1 Answer
Chosen Solution
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
Score 2
Add a comment
Add your answer
LHolder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 147
