Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Questions View all
If I buy the 256GB flash only, can I install a HD?
If I buy the flash-only option, is there still a SATA connection available to install a hard drive as shown in:
iMac Intel 27" Retina 5K Display Hard Drive Replacement
Score -1
Add a comment
1 Answer
Chosen Solution
Almost! You'll need a few pieces as Apple doesn't install the needed cable and mounting screws. The logic board has the needed connections.
Frankly, I would get the model that meets your needs Vs trying to upgrade this system. This is not an easy system to open and if you mess up the display assembly is quite expensive!
Score 2
Add a comment
Add your answer
Davood Bonyad will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 115
