Why does my desktop backround look like a file explorer
The picture above is what it looks like.
This happened when my young brother pressed all of the buttons in my Razer mouse and the desktop changed into this
Hello,
You may try the following;
>> Go to task manager. (Press Ctrl + Alt + Delete)
>> In the Process tab, look for Windows Explorer.
>> Right click on Windows Explorer and select Restart.
This should reset your desktop back to normal.
This tool was released by the WindowsClub and can be downloaded from here. Once you have it on your computer, unzip it and run its main executable as admin (Right click -> Run as administrator).
Once the application is open, select the folder for which you want to remove the background image. Then, click on "Remove Background Image".
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 160
