A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Questions View all
Question Closed
Can I use a separate RAM stick with a dual channel kit?
Hello !
I currently have a dual channel kit in my computer and i want to purchase one more RAM stick (same specs but just not in a kit).
My question is : If i would buy the other stick of RAM wich is identical to the ones in the dual channel kit will it effect the dual channel configuration?
Add a comment
1 Answer
Chosen Solution
Hello Hikary Katsu
Yes you can buy a identical single stick and install it. Most people in the industry will say that you should buy memory in a kit (16GB kit 4x 4GB or 2x 8GB) but in over 10 years I have been in the PC industry I have not has any trouble with mixing kits. You might run into problems if you start to mix brands. I have ran into certain brands that don't get along together but others do.
The reason most people say don't mix kits is because the ram in kits, are made and tested together so there is less chance of failure, but if you run memx86 (http://www.memtest.org/) and it passes after 5 passes then you shouldn't have any trouble. I think also most retails say you have to buy a kit is because you will need to buy more. Like in your case you have 2 sticks of ram already installed and according to retails they expect you to replace all of your memory and not offer a trade-in. Any business that is offering that, I would be questioning their motives.
Score 1
1 Comment:
The additional RAM stick that i want to buy is exactly like the ones in the kit,it just isn't in the kit.
Thank you for your answer,have a good day !
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 2,597
