Released on October 1, 2013 the BLU Studio 5.5 is an unlocked Android smartphone with two model types being the D600 (single SIM) or D610 (dual SIM).
How do you calibrate the screen?
When I try to tap my screen it'll select something else
Add a comment
1 Answer
Chosen Solution
Hi,
Check if there is a Touch and Hold Delay setting in your phone. If there is, set the option to short.
To find Touch and Hold settings, go to:
Menu > Settings > Accessibility > Touch and Hold
Score 3
4 Comments:
I already tried that, it didn't help.
by
Hi,
As a test, rotate your phone 90 degrees (so that it is in landscape mode) and see if you have the same problem. It may be an area of the digitizer that is faulty. Alternatively, backup your phone and perform a hard reset. This should restore your phone to factory default condition.
by
I tried to reset and everything still doing the same thing might be calibrate I have not try it yet
by
I got problem with my phone as well done everything but! No change with key pad?
by
Add a comment
Add your answer
Naci will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 13
All Time: 9,261
