Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
573 Questions View all
Freezes and screen won't turn on after shutdown
Hi,
I'm having a lot of trouble with my iMac, and I can't figure out what's wrong with it. The problem is if I use the mac for a period of time, sometimes it can be almost a whole day other times it can be a hour. It all of the sudden freezes completely and the only way of getting it to work is to do a hard shutdown (holding the power button until it turns off).
But when I try to turn it on back on the the screen won't turn on. And I have to again do a hard shutdown, sometimes it takes around 5-6 times before the screen turns on. And if the problem occurred once and I try to use the Mac immediately after, it freezes within the first 10 minutes, and the whole procedure has to be repeated for another 10 minutes of usage. The only way to get it to not freeze up is if I don't use it for like a day, but that still only gives me around 3-4 hours before the problem occurs again.
I sent it to a repair shop to get it fixed, I figured that maybe its the hard disk. They ran some Apple test and told me it's not the hardware but the software causing the problem. So they factory restored it and gave it back to me. But it didn't fix the problem.
Any thoughts on what could be the cause of this?
Score 1
Add a comment
1 Answer
Most Helpful Answer
First remove the frame and observe the diagnostic lights and tell us your findings. Next see if you can get an external monitor and the corresponding adapter.
Score 1
Add a comment
Add your answer
Liam Spilberg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 357
