Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20000 Questions View all
Question Closed
MBP won't power on unless I remove the hard drive
I bought a macbook pro a1286 2010 model and was told it was probably a DC jack issue that caused the computer to not power on.
Just being curious I plugged it in and turned it on, and it worked just fine.
Then I installed a new hard drive and now it won't turn on.
So I replaced the DC jack, still it won't turn on
So I took the hard drive out, and it turns on fine.
That being said, I can't turn the computer off by simply holding down the power button. I have to unplug it for it to turn off
I've installed a new SATA cable to see if that was the issue, and still the computer only powers on without a hard drive installed.
What could be the issue here?
2 Comments
what make and model is your HDD?
by
I've installed multiple just to rule out the hard drive
1 - seagate 320gb
2 - fujitsu 160gb model MHY2160BH
by
Add a comment
1 Answer
Chosen Solution
It was a bad logic board
Score 1
1 Comment:
So basically you gave up on it.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 86
