Put diesel in by mistake
I accidentally put diesel in gas tank. How do I fix it other than emptying tank?
Remove as much fuel as possible then fill it with fresh gas. It will smoke for a while and after a while you'll want to put carb cleaner through it to remove any heavy fuel that remains in the fuel system . If there's an inline fuel filter you may want to change that after you've gone through a tank of fuel .The oil in the diesel will cause a gas fuel filter to clog
if you did not put much in run it it will smoke and keep putting all the gas you can
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,773
