The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
Touch not working after replacing screen
I replaced the digitizer only an iPad 3rd generation. I haven't sealed it. It does come on and Siri comes on but the touch isn't working. Help!
Score 1
Add a comment
1 Answer
If possible, remove the new digitizer, and test the old digitizer to make sure it's not an issue with the iPad's logic board.
If the old one works, you'll know you need to replace the new digitizer as it would likely be defective.
2 Comments:
I can't put the old one back on because it shattered.
by
I should say I shattered it when I took it off. it only had a crack prior to my replacing it :(
by
Add a comment
Add your answer
Donna will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 131
