Repair manuals and support for 4-wheeled passenger and cargo vehicles.
11828 Questions View all
1999 Plymouth Voyager electrical issues.
Intermittent instrument clusters working. Today battery wont hold a charge.
1999 Plymouth Voyageur. 300k+ km. Last winter the instrument cluster stopped working, started again in the spring. It quit again a month ago. Replaced the cluster with the same result. Yesterday, I left the door open for about ten minutes (interior lights on and engine not running) needed a boost. Today the van stopped running while driving (battery died). Headlights, radio and fan on. Had the van towed home
Battery is about a year old. Tested three times and it is "ok".
Is this a ground issue? Do I need an alternator? Computer?
Any thoughts?
Help!
Dave
Add a comment
1 Answer
Chosen Solution
Start by cleaning your battery terminals then test the alt with multi meter you defiantly have issue with your electrical system
Score 2
7 Comments:
The battery terminals are very clean. Code 771-775. Ok, I will try to find one
by
the code your getting is it a p0 or a b0
by
does the van shift from gear to gear ok
by
I don't know which code it is getting. Yes, the transmission shifts ok
by
you mentioned code 771-775 what do you mean here are these obd codes?
by
Show 2 more comments
Add a comment
Add your answer
davedziedzic will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 308
