The Xperia Z1 Compact is Sony's premium camera phone. It is similar to the Xperia Z1 model except smaller and less expensive. Its key feature is a 20.7 megapixel sensor. Upon release the available colors were white, black, pink, and lime. This device can be identified using the model number (D5503)
29 Questions View all
How to clean dust from camera?
Hi guys!
I want to ask if it's possible to clean the dust from my phone's camera. I don't even know how it got dusty :( (if you need I'll post pics)
1 Comment:
Maybe it is not the dust from camera but on the camera lens? No matter which one, if you want to clean the dust, you may need to remove the back cover firstly, and then use the soft cloth to clean dust.
by
Add a comment
use a sharp object like blade( insert it to the any edge of the round lens cover) to pull the lens cover (be careful with that) and blow the dust out (use ur mouth to blow) or a soft cloth
2 Comments:
Well I'm a bit afraid of your method I think I'll just pass this :s
by
it is sooo simple and easy you just have to be steady are careful...
if you get the same phone i will demonstrate of for you with VIDEO
by
Add a comment
If you want clear the rear camera dust, you need remove the back cover. The first time the phone is disassembled, it needs some tools and operations.
This Sony Xperia Z1 Teardown can help you disassembly the Xperia Z1.
Add a comment
Add your answer
domohpi will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 8
All Time: 2,290
