Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
My iPhone has black and white lines!
Theres also some colorful lines on the left. I can kinda see my date,time, and my battery percentage. So what happen was i took off the screen but all i did was remove the metal plate and some screws that connects the screen to the phone. When i tried to swipe it, it kinda go crazy.
Score 1
Add a comment
1 Answer
Take the phone apart again, remove the connectors, and clean the connectors on the motherboard very carefully. Check the motherboar connectord to make sure none of the pins are broken, missing or bent. Put the connectors back on until you heard them click, just like Legos and put the screws back in correct location, can't mess the screw locations up!! Then do a soft reset by holding down the power button then push and hold the power button until you see the apple icon and phone should be up and working!
Add a comment
Add your answer
christychen20 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 2,968
