How to restart UI system?
My UI system has stopped working and wondering how to get it restarted?
Score 2
Add a comment
1 Answer
Chosen Solution
Hi,
On the back of the tablet there is a paper clip sized hole marked "reset". Gently insert a paper clip into the hole. You will feel like you are pushing a button. Hold it down for a few moments, then withdraw the paper clip and restart your tablet.
Score 4
8 Comments:
The unit is still telling me the UI system has stopped.
by
Hi,
Unfortunately a "soft" reset did not work for you. Here is a link which details how to "hard" reset your tablet. Be aware that a hard reset restores your tablet to factory default conditions and you will lose all your downloaded apps/data and user settings.
http://www.rcatablets.com/how-completely...
by
I tried that and all it said was 404
Page not found
The page you requested does not exist
Does no good tone reset
by
Hi @Jessica Anne
Try the following:
1. With your tablet turned off, press and hold the volume up (+). While holding the volume up (+) button, press the power button until you see the RCA logo with Nipper and Chipper. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
2. Press and hold the tablet’s power button, and without releasing the power button press down on the volume up (+). You should then see the screen below.
3. Use the tablet’s volume up (+) and down (+) to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
2 part answer
by
2nd part of answer
4. Use the tablet volume up (+) and down (-) keys to navigate to and select "Yes – delete all user data." use the power button to select this option.
5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
6. The system will begin to reboot and once again display the RCA logo with Nipper and Chipper. The next "Welcome" screen will prompt you to select your language of choice. Scroll through the options using your finger and press start when finished.
by
Show 3 more comments
Add a comment
Add your answer
plshupert will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 2,449
