iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Why is my iPod classic get hot under the clic wheel
Hi all, My ipod classic went dead on me, no biggy, until it would't charge(I notice when pluggin it would get warm/hot under the clic wheel near the play button). I replaced the battery, and it turned on just fine. With the new battery it still will not charge, gets warm/hot and does not register to ANY power souce. The battery is still charged form the factory, but since it will not charge I am not using the ipod
Any suggestions?
Thanks.
Score 1
Add a comment
1 Answer
Chosen Solution
grampdc3 you would have to take it apart and take a look at what might be causing this. Heat usually means there is a short circuit. Check the battery connector, it has a tendency on this model to come loose on the logic board. There are really no components on the click wheel side of the board that could generate heat. You do want to check the dock connector as well to make sure that it does not have any bend, broken or corroded pins. Worst case scenario is a shorted out power management IC. Use these guides to work on your iPod.
Score 2
2 Comments:
Thanks for the info oldturkey03! I will give it a shot, cause the ipod is useless the way it is right now!
by
Let us know what you find. That model iPod is a great player and I would even replace the logic board if I would have to.
by
Add a comment
Add your answer
grampdc3 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 515
