Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Question Closed
does not charge, does not show connection to I tune.
I fix the broken screen of I6 and put back together. worked great. I realize it was not charging keep on saying cable is not compatible. I tried this
hold the dismiss and unplug the charger and put back in. It showed charging sign but actually didn't charge. I noticed charging percentage was going down.
I connected it to computer and tried to upgrade the software, then it stuck in I tune showed the problem of -18 and later on 2001.
I have soft ware downloaded to get exit from i tune ( i phone care for Mac) and I tried to exit but it say no connection to the computer while there was connection. I got new cable from at&t store compatible with apple. again it did not help.
How to solve this. I have same problem with I 4s too.
Add a comment
1 Answer
You might need a new charge port. Also try using a full original cable from the Apple Store.
1 Comment:
I tried both , did not work.
by
Add a comment
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 73
