Released in 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer.
709 Questions View all
I Just replaced the DC in-board, still not charging?
I ordered the DC inboard part from IFIXIT.com I replaced it with the iFixit instructions. But the computer won't charge, nor will the charging light turn on. Has anyone has this problem? Could the problem by my battery instead? Any Advice?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
If your light on the AC adapter was not turning on before you replaced the DC-IN port, the adapter would be the main suspect. Here's a nice replacement. PowerBook G4 Micro Accessories AC Adapter (New)
Score 1
Comments:
Next I would download and run Coconut battery: http://www.coconut-flavour.com/
Then go here and identify your Book: iBook G4 Repair
Look up the Battery transfer board Apple part # 922-6183. It works in all iBook G4's and is only $9.45. iBook G4 14" Battery Connector
Here's how to put it in: iBook G4 14" 933 MHz-1.33 GHz Battery Connector Replacement
by
Add a comment
Thanks for the advice. However, I tried using a friend's adapter who has the same computer. His adapter, while still working for his, does not charge mine with the new dc-inboard installed. Oddly, his adapter stops charging his computer after it has been plugged into mine. After he disconnects it from the outlet and plugs it back in the charger continues to work on his computer but not mine. Any thoughts?
Add a comment
Updated
Add a comment
Add your answer
hsiehliza12 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 941
