no transfer of power to 1998 ford ranger 4x4 transmission drive shaft
The clutch and slave cylinder work correctly but with the transmission in any gear there is no transfer of power to the drive shaft. The transmission seems to shift correctly thru all gears.
1 Comment
Byron Jessee not quite sure what you are saying. You press the clutch and place the Ranger in gear and then what? What happens when you place it in gear before starting?
by oldturkey03
