No display with distortiom
The link below shows the problem that I am having with my LG tv 32LH3000.
Can someone help me how to solve this issue?
The below are photos of the motherboard and psu.
Manuel, unplug your set and take the back cover off. Take a look at the power board and check for leaking or otherwise damaged capacitors as well as other obvious damage. Post some images of your boards so we can see what you see. Judging by the video it appears to be either a power board or LCD issue. Use this guide to add images to your question.
Thank you will do this evening
Photos are uploaded
Kind of hard to see but unless you want to test the components on the board itself, I'd replace the power board next. Let me know so I can send you the service manual
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 269
2 Comments
Two basic troubleshooting steps you can try:
1. Try a different input
2. Try a different device on the inputs
Please update your question with the results.
by hakugingin
Hi,
The problem is not with the input
The problem is when I switch on my tv it only shows as seen in the video. The problem occured when we had a power cut and when the power come back. Could be power supply or motherboard issues?
Many thanks for your help =]
Manuel
by Manuel
