1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
139 Questions View all
Question Closed
Why won't it boot?
My macbook air has been in storage a while unused. I plugged it in today and the liught glows orange as it should and green. It won't boot though! I press the power button, and it doesn't.It doesn't SMC bypass either BUT it does do an SMC RESET all ok so I guess the power button works. I left it oncharge by now about 1 hour but it still doesn;t boot up? Any idea? Seems fine inside...
Add a comment
1 Answer
Most Helpful Answer
Press the battery indicator button on the side and see what you get. let it charge all the way up. Then give it a try.
Score 1
2 Comments:
there is no battery indicator? I will charge it overnight hopefully then it will work
by
It worked, I changed the magsafe and it worked all fine. I changed to a 45W but before had a higher W - not sure but it seems it likes the 45W one only?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 90
