problem with replacing logic board
I have an 20‘‘ iMac 4,1 with a 2 GHz Intel Core Duo (modell 1174, logic board 820-1888-A). Installed is Mac OS X 10.6.8. Because I wanted to install some applications which need a OS X version greater than 10.6.8 I bought a used logic board 820-2031-A with an Intel Core 2 Duo. I used the iFixit-guide to replace the logic board and until then everything went find. But after finishing my work the iMac didn‘t power on. Cause I were not sure, if I hadn‘t made a mistake, I repaced the old logic board. The result was, that the iMac started normally without any problem. I mention, that the problem is something with the C2D-board. I found some threads about iMacs not powering on after logicboard replacement and I started to figure out what the problem could be. I tried to reset the SMC and put a new battery in but without any result.
So I tried to find the diagnostic LED‘s of the board, but on the board 820-2031-A I can only find 3 diagnostic LED near the bottom and not the described 4 LED‘s. Is this ok or is there somewhere another, the 4. LED? If it is correct, that the board has only 3 LED‘s, what are the functions of those? Are they simular to the first 3 LED‘s of the discribed 4 LED version?
And the last question: Is it possible to test the board outside of the iMac? If yes, what is the way to do this?
I hope you can interpret my bad english an anybody can give me some hints. Thanks from Germany.
Did you ever figure out how to get the new mainboard to work? Id like to do the same if its possible.
by stevenvaden
