PowerBook G4 Aluminum laptops with 12-inch displays. Released in 2003 from Apple.
149 Questions View all
PowerBook won't Read Hard Drive
Hi guys... I'm having the same problem as this question with my Powerbook G4 12" DVI. Couple years ago I had to change the hard drive and it was ok until a few months ago when it simply stopped working. I took it out, managed to recover the files and tested the drive on another Mac as well as on a PC and the drive works fine. Only internally in the Powerbook that it does not... Neither disk utility nor system profile (hardaware/ATA) recognize it. So it seems that it's a bad logic board or cable right? Is it common for a hd cable to go faulty? Nothing out of the ordinary happpened to it. I fear it's the logic board.... If anyone coud shine me a light it would be much appreciated.
Cheers
Score -1
Add a comment
1 Answer
Chosen Solution
Does the computer recognize any hard drive? If not I would try the cable first-(cheaper part) and if that fails you may have a bad logic board. Good luck Ralph
Score 2
Add a comment
Add your answer
Felipe will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 509
