Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7
265 Questions View all
power supply issue, no boot, now boots
I am the original owner of this iMac 27" late 2010 model, today I was copying fils from one external hard drive to another external hard drive (one drive has its own power supply the other is a 2.5" laptop drive not self powered).
I was also looking around the net and noticed that the progress bar for the copy had not moved at all and would not cancel, I tried to restart but because it thought it was still copying it would not...I waited 30min, then held the power button down to force a restart that didn't work either, it just sat there, I unplugged it for 30 seconds.
Plugged it back up and pressed the power button and it would not boot at all !
no noise, no fans, nothing.... I searched around found that this model has some diagnostic LED's and looked at those 4 little lights, I plugged it in and looked,
ALL WERE OFF!
LED 1 should be always on if the power cord is in, so I tried another cord, same result. Also tried a different outlet.
I did some more research and my guess is the power supply, I unplugged the computer and came back to it about 5 hours later, plugged it in and it POWERED UP like nothing ever happened!
I ran a program to check the temps, GPU, CPU, SSD, Logicboard ect... and even during a 3d game the cpu got to 120deff and the GPU got to 130degf....
Could I have a bad power supply ? to much current on the USB with the external drives?
I have used them like this before, backing up photo's and such.
Comments:
Please tell me the model and name of the external drive
by
toshiba 1TB dc+5x 1amp model v63600, and an older western digital 2TB with built in power. Also had a thumb drive on the keyboard and that was all the USB devices powered, I have copied several files just now no issue, I am attempting to get the thing hot and see if it does it again... I hate intermittent problems
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Sounds to me like a failing component on the power supply or a failing solder. When it heats up it fails or separates. I would remove the supply and visually examine it for suspicious solders and attempt a repair before buying a new one. Here's some info on "identifying cold solders" .
Warning: be very, very careful when removing the display to logic board connector as it can be damaged.
Score 2
Add a comment
Add your answer
nickademusss will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 81
