Why does my camera not connect to the computer?
My camera accepts the USB cord but will not register on the computer.
It is possible that your USB cable is not working, so you should try using a different cable. If that doesn’t work, try connecting your camera to a different computer. It is also possible that there is a problem with the camera software on the computer, so you should try uninstalling and reinstalling the software onto your computer. If that doesn’t work, try using a different USB port on your computer. If none of the above works, you should clean out the USB port. Also, remember to make sure you are using the right kind of cable.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 98
