This is a laptop designed and manufactured by Lenovo for entry level business applications. This model number is WB0201130E.
10 Questions View all
How do you find the correct charger to buy for a laptop?
I had recently lost my charger and cannot find it. My batteries are out and I decided to just go ahead and buy a new one. How do I go about knowing which charger to buy?
Score 1
Add a comment
1 Answer
For the Lenovo Essential B570 there should be a sticker on the underside of the laptop. This sticker provides all of the details needed for what charger is required.
If your sticker is missing, the Input voltage should be 20Volts and 3.25 Amps. When deciding a charger, you can see the volts and amps they provided listed on the chargers description online, or on the actual charger itself.
Also, make sure that the charger actually fits in the port. When buying the charger from the manufacture (Lenovo in this case), check to see the listed laptops the charger will be compatible with.
Add a comment
Add your answer
Mathew Callahan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 116
