Pink screen with 4 black lines then screen goes black.
After doing a screen assembly replacement my screen now sometimes goes pink with four black lines through it then goes black.
It started when charging.
It comes back on later and is fine for awhile and then happens again.
Please does someone know if the screen assembly I purchased might be faulty?
Score 1
Add a comment
1 Answer
Chosen Solution
Hello Karismac,
Please check Display FPC (Flexible flat cable) cable properly connected to the FPC connector on logic board. This guide will help you to fix it your self : (see step 19)
After checking above step if same fault observed, replaced display acceptably could be fault.
Score 2
Add a comment
Add your answer
Karismac will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 62
