Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
no service and constant searching sometimes?
I replaced my iPhone 6 plus housing and everything works but service!says searching or no service and wifi works and it reads my sim but still says no service?reconnected antenna for service 4 times still same issue even with restore!ordering new cable hope it's fixes it.but if anyone has had this issue or knows what it is let me know?
Score 2
1 Comment:
Have you checked you have an imei number?
by
Add a comment
replace the 5GHz Wi-Fi antenna
1 Comment:
Why the wifi antenna?wifi is working
by
Add a comment
Did you buy the housing with flexes already installed? In the early days with another supplier I found the housings always had poor quality or faulty parts installed. I had this issue on a 5C housing I replaced once, and it was the lightning port flex on the new housing. So I simply transferred the original one over to the new housing. The cellular antenna is on the back of the speaker, but connects to the motherboard via the lightning port flex and cable. Wifi antenna is at the top of the phone, and nothing to do with cell reception.
Add a comment
Add your answer
wassofrank will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 5
All Time: 561
