2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Questions View all
Display and back logo don't work
Hi all! I have the following issue with my MBP 15" Mid 2015. Display cover was strongly closed so display and apple logo in the front doesn't work. MBP works normally with external display. I've tried reseting SMC and NVRAM, but it didn't help. I've tried reconnecting display cable aswell but nothing happened. Is there anything else I may try to do before changing the display? Thanks in advance.
Score 1
Add a comment
Chosen Solution
You can try to shine a flashlight through the Apple logo and see if you can see a faint picture on the display. If so, then there's a problem with your backlight.
It's quite easy to open up the MacBook and check the cables. Just follow this guide (not the exact same model, but close enough): MacBook Pro 15" Retina Display Mid 2014 Display Assembly Replacement
If checking the cables doesn't solve things then your backlight fuse might be fried and has to be replaced. This is a board level repair so very difficult to do yourself.
Score 3
2 Comments:
Hi, thanks for your answer. I've tried using a flashlight and I was able to see the picture. So is it possible to repair a backlight myself? Thanks in advance.
by
You could try and check to refit all display connectors when opening up the MBP. If that doesn't help then there's probably a problem with the backlight fuse. This is a very hard repair to do yourself. It involves board level repair with microscope soldering.....
by
Add a comment
Swap it for a different display assembly to see if it's the display or the logic board issue.
If it's the logic board, board level repair is better than just replacing the board.
Score 1
Add a comment
The cable is most likely dislodged from the lcd rather then the logic board you could try taking the display off and tapping it upside down to see if you can get it back into place without taking the glass off. I know this seems like a weird fix but its worked in the past with dropped iPads and MacBooks.
3 Comments:
Hi, thanks for your answer. I've tried removing and tapping the display but it didn't help. Is it possible to disassemble screen and check if all cables are fine? Thanks.
by
you will have to separate the glass and either replace the lcd or lcd cable. Not a super easy repair but worth it. Otherwise you would be looking at $150ish for a used replacement assembly.
by
please help . Change a screen of macbook pro retina 2015 and now not backligth . please help . I need remplace fuse . Please send picture fuse backligth . thanks
by
Add a comment
Add your answer
Smilley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 2,843
