First generation Bose SoundLink Mini released on July 1, 2013. The device weighs 1.5 pounds and has a Bluetooth range of 30 feet.
46 Questions View all
Question Closed
I am having trouble with Bluetooth pairing on the SoundLink Mini.
My device will not connect/pair with the speaker (or the speaker can't find my device). I want to listen to music, but it just will not connect. Please help!
Add a comment
1 Answer
Chosen Solution
1. Make sure the software on your speaker is up to date.
2. Reset your speaker using these steps: On the speaker, press and hold mute for 10 seconds, the LEDs will flash briefly. Then press Power to turn the speaker back on.
3. Make sure your device is within 30 feet from the speaker.
4. Make sure your device is in bluetooth mode.
5. Check your devices pairing list and make sure your speaker is the one selected.
1 Comment:
Spot on worked first time really appreciate this as I was close to consigning the little chap to the dump!
by
Add a comment
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 4
All Time: 239
