A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
F:01 error code when trying to wash clothes
What does F:01 error code mean?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Mac Jones, F01 is the code for a failed main relay power control board. If you remove the board, take a look and see if you have any obvious damage which might be repairable. Take a look at the wiring as well as the components and connectors, check for corrosion.
Score 1
Add a comment
Add your answer
Mac Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,355
