Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 Questions View all
LCD has a gray bar of pixels after digitizer replacement
Hello! I have replaced the digitizer on an iPad Air, and the top rows of pixels are grey after that. It is about half a centimeter of mostly gray pixels, but below that, the screen works just fine. What can have happened?
Thanks!
Add a comment
Chosen Solution
Probably didn't connect it properly. Could possibly be a bad part
iPad Air Screen Digitizer
iPad Air Screen Digitizer Image
Product
$39.99
Score 1
6 Comments:
No, it's connected alright. The digitizer that II installed works just fine, and the LCD is the original. It worked before, but after the replacement it has a grey stripe.
by
You could try disconnecting the display cables, disconnecting the battery, re-connecting the battery, then re-connecting the display cables. Sometimes this works. It's called cycling the battery
by
It doesn't seem to work. I will try to avoid disassembling the whole iPad.
by
Ok, well. I'm going to guess its the part that's the issue. Try using a quality part, like the one I suggested earlier
by
I only replace the digitizer. The LCD is original. Even when the digitizer is fully disconnected, the gray stripe is still there.
by
Show 1 more comment
Add a comment
Your lcd was broken during your digi replacement. That's what they look like (sometimes) when they're broken.
Add a comment
Add your answer
Edvin Jacobsson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 229
