A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1696 Questions View all
The fan runs on high, 3 beeps to red light
i just replaced a motherboard on the PS4, after it powers on after it beeped once
the fan startin to run on high. goes from blue to white to red light and it beeps 3 times and it shuts down
the HDD is in and the screw tighten
before it was doin that, PS symbol popped on the screen and had an error code CE-34335-8
now it's not doin nothin except makin the fan run be loud plus the 3 beeps and red light
2 Comments
I didn't replace the motherboard, however i got the over heating error so I took my ps4 apart completely. now it does what was mentioned here the blue light and restoring screen then halfway completed it beeps flashes red and shuts off. I just sent out my hubby to get thermal paste as there was very little on it when putting it back together. hopefully this works.
by
I have the same problem but when i turn it on i don't hear the fan at all, could this mean that my fan is jammed or something
by
Add a comment
1 Answer
Chosen Solution
Your PS4 is overheating. You likely either didn't get the heat transfer pads on the memory chips correctly, didn't use enough thermal paste on the APU or didn't tighten the heat sink clamp down ( I see a lot of them that have been installed upside down as well).
I would look over all of those things very carefully as one of them is most likely the cause of your problem.
I hope this helps.
Score 4
8 Comments:
i will check on those 3, thanks for the advice
by
Let me know what you find!
by
now it's sayin cannot access system storage and it's in and snugged with the screw
i can go to safe mode, yet, it wont let me do anything cause of the hdd
is the hdd supposed to snap in or just slide in, but i am still wonderin bout the 4 prongs on the hdd bein free
thanks
by
It just slides in. What 4 prongs are free? If it can't access the HDD then you likely need another one.
by
@tronicsfix and @zigler54 . Hello guys I repaired the 4 pin for power supply and attached my motherboard back. Same issue as mentioned above but not sure where to get thermal pad from or is there any alternative for it or is normal mounting tape good enough to replace lost thermal pad.
by
Show 3 more comments
Add a comment
Add your answer
zigler54 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 16,653
