The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
Wi-Fi on the blink!
Wi-Fi connection is very inconsistent, but mostly not connected even when right beside the access point. But it does connect at times, as if nothing was wrong. Then most times it can't find any wireless sources at all. How should I go about evaluating this problem? I am guessing maybe a loose antenna connection? Or is it the communications board? Or the logic board itself? I hope not! Any tips, anyone? Thanks!
Score -1
Add a comment
1 Answer
Chosen Solution
So it looks like it was loose wire connectors after all! After successfully replacing the battery, before closing up, I re-seated the wire connectors, then after closing up, I have a fresh new battery and Wi-Fi is back, too! Yesssss! Thank you for all your help, iFixit! More Power!
Add a comment
Add your answer
ianjosef will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,061
